Microsoft edge favorite icons not loading
Mark Martinez 15 Reputation points
2025-06-19T17:08:32.28+00:00
This problem occurred after reformatting/resetting my windows pc. So basically, whenever I favorite a website, its icons turn into an earth-like icon instead of its true icon. What do i need to do to fix this issue?
Microsoft Edge | Microsoft Edge development
  1. G225 - MVP 2009-2020 26,585 Reputation points Volunteer Moderator
    2025-06-24T06:41:48.4033333+00:00
    Manually visit each favorite to force the loading of its favicon.
    Clear the cache via edge://settings/clearBrowserData, then restart Edge.
    Temporarily disable extensions, especially those related to security or privacy.
    Make sure Edge is up to date.
  2. Damien Pham (WICLOUD CORPORATION) 2,135 Reputation points Microsoft External Staff Moderator
    2025-07-16T08:36:05.6533333+00:00
    Hello Mark Martinez,
    Here are the steps to Fix Missing Favicons in Bookmarks
    1. Clear Browser Cache
    Sometimes the favicon cache gets corrupted or doesn't refresh properly.
    In Edge: Go to SettingsPrivacy, search, and servicesClear browsing data → Choose "Cached images and files" → Click "Clear now".
    1. Revisit the Bookmarked Sites
    Favicons are usually reloaded when you visit the site.
    • Open each bookmarked site in a new tab.
    • Wait a few seconds for the favicon to load.
    • Close the tab and check the bookmark again.
    1. Reset Favicon Cache (Advanced)
    If the issue persists, you may need to manually reset the favicon cache.
    • For Edge:
      1. Close Edge.
      2. Navigate to: C:\Users\<YourUsername>\AppData\Local\Microsoft\Edge\User Data\Default
      3. Delete the Favicons file.
      4. Restart Edge and revisit the sites.
    1. Check for Browser Updates
    Make sure your browser is up to date. Sometimes favicon issues are fixed in newer versions.
  3. Duane Davis 0 Reputation points
    2025-12-05T15:17:19.2433333+00:00
    Sign out of Edge/Microsoft Acct.
    Sign back into Edge/Microsoft Acct.
  4. Chanaka Palliyaguru 0 Reputation points
    2026-08-13T08:35:02.7233333+00:00
    Resetting Edge worked:
    1. Close Edge.
    2. Press Win + R, type %localappdata%\Microsoft\Edge, and click OK.
    3. Rename the User Data folder to User DataOld.
    4. Start Edge.
    Note: Make sure your bookmarks are synced to your profile/account. If not, you will lose everything.
