Error while saving any changes in edge manifest in IOT central.
Priyanshu Aggarwal 25 Reputation points
2025-06-19T06:43:26.8466667+00:00
Recently, I have been facing issue regarding edge manifest in IOT central. Whenever any changes needs to be done by edit manifest option, it pops up an error when I try to save it.
The error I get:
Problems loading reference 'https://json.schemastore.org/azure-iot-edge-deployment-2.0.json': Unable to load schema from 'https://json.schemastore.org/azure-iot-edge-deployment-2.0.json': Failed to fetch.(768)
Azure IoT Central
Azure IoT Central
An Azure hosted internet of things (IoT) application platform.
Sander van de Velde | MVP 37,081 Reputation points MVP
2025-06-19T07:15:23.4433333+00:00
Hello @Priyanshu Aggarwal
welcome to this moderated Azure community forum.
Can you elaborate on what you mean with 'edit manifest option'?
If this is done in the portal using the UI, there seems to be something broken.
In that case, create an Azure support ticket so the backend an be inspected by the support team.
UPDATE AFTER DISCUSSION
It seems the User Interface experience in the portal is deprecated.
The product team is engaged to fix this.
Either uploading the full manifest (edited outside the portal) or using CLI commands are a workaround.
If the response helped, do "Accept Answer". If it doesn't work, please let us know the progress. All community members with similar issues will benefit by doing so. Your contribution is highly appreciated.
0 additional answers
