An Azure service that is used to share data from multiple sources with other organizations.
Problems with existing Datashare and existing Datalake connection during Add Datasets - Failed to retrieve Azure Datalake folders
Catherine Quinn
0
Reputation points
Trying to add Azure Datalake gen2 datasets to an existing datashare.
I have added datasets from this exact folder many times previously. Datashare has all of the necessary permissions on the Datalake to view and retrieve files. I can see the top level folders in the datalake but none of the datasets (.txt files) are showing. Says 0 datasets.
ERROR: Failed to retrieve Azure Datalake folders at this moment. Please try again later.
Very frustrating. Help would be appreciated. Thank you!
Azure Data Share
Azure Data Share
Sign in to answer
