Accessing IoT edge device's managed Identity from IoT edge module
2025-05-21T15:11:04.43+00:00
Hello! I am currently having a problem with my Azure IoT setup.
I have an edge device that runs several IoT modules based on docker containers which run python code. Within this code, I need to authenticate against other Azure resources. Ideally I would like to use Managed Identity Authentication to do this.
I got the answer that the recommended solution in this case is to get managed identity support by enabling azure arc on the edge device (see answer by @Suwarna S Kale in the question here: https://learn.microsoft.com/en-us/answers/questions/2264733/receive-credentials-from-keyvault-within-an-iot-hu).
I installed azure arc on the device and it works fine, showing up in the azure portal. I also verified I can access the managed identity endpoint (localhost:40342) from a local shell on the edge device.
My question is: How can I access the endpoint on the host edge device from within an IoT edge module? I have tried host.docker.internal:40342 as well as 172.17.0.1:40342 , but I always get connection refused errors. Are there additional settings to be made to the edgeAgent and/or edgeHub modules for this to work?
Thank you for your help!
Azure Internet of Things
Sander van de Velde | MVP 37,081 Reputation points MVP
2025-05-22T16:06:06.3233333+00:00
Below you find the solution as shared by the original poster @Anonymous :
In general, I am a bit puzzled why using the managed identity of the device for module-level MSI authentication is the recommended method, because getting it to work properly requires quite some hacking, opening up other security issues on the way.
So the problem is that the azure arc install script sets up the IMDS endpoint to 127.0.0.1:40342 and NOT to 0.0.0.0.40342. This is probably done for security reasons, such that you can only access the managed identity when on the actual machine (which makes sense). On the other hand, it renders the identity useless when working with containers like in my case using the IoT Hub, because the host 127.0.0.1 can't be accessed (except setting network=host, which is also not optimal in my view).
In order to use the managed Identity I had to expose the local endpoint somehow such that docker containers could access it. Here is what I did:
I created a daemon on my machine that uses socat to create a TCP relay between some (unused) port bound to 0.0.0.0 and 127.0.0.1:40342 . Note that this will expose the identity endpoint to your local network. It is fine for my use-case. In more critical use-cases, one should probably take measures to block acces to this port except for the docker host local IP (172.17.0.1).
Then, all containers that need to access the identity must have at least read-only access to /var/opt/azcmagent/tokens on the host system. Therefore, in the "container create options" in the IoT Hub, you need to include:
"Mounts": [
    "Target": "/var/opt/azcmagent/tokens",
    "Source": "/var/opt/azcmagent/tokens",
    "Type": "bind",
    "ReadOnly": true
in the "HostConfig" section.
Finally, if you don't want to rely on REST API calls in your code but use azure.identity.DefaultAzureCredential or azure.identity.ManagedIdentityCredential, you need to set some environment variables. Let's assume for the free port I mentioned above in the TCP relay I used 0.0.0.0:12345, then the following variables need to be set in the container:
IMDS_ENDPOINT needs to be set to http://172.17.0.1:12345 and IDENTITY_ENDPOINT needs to be set to http://172.17.0.1:12345/metadata/identity/oauth2/token.
Only then everything will work and you can access azure.identity -based managed identity credentials in your code on an IoT edge module to authenticate against other resources.
If the response helped, do "Accept Answer". If it doesn't work, please let us know the progress. All community members with similar issues will benefit by doing so. Your contribution is highly appreciated.
0 additional answers
