How to do Low Level Design for Given HLD in Azure
Relay 320 Reputation points
2025-05-18T03:57:50.1766667+00:00
I have created a High level design where I am consuming JSON file from Azure Stream Analytics to Azure SQL.
What all are properties I should consider for creating Low Level Design for same.
ASA-ASQL-LLD
Please help me with your expertise knowledge.
Thanks a lot
An Azure real-time analytics service designed for mission-critical workloads.
David Broggy 6,801 Reputation points MVP
2025-05-18T06:27:27.7366667+00:00
Hi there,
Here are some low level consideration for your stream analytics architecture:
Low Level Design: Azure Stream Analytics to SQL Integration
  1. Data Source & Input Configuration
  - Input Type: JSON data from Azure Stream Analytics
  - Serialization Format: JSON (configure compression if needed)
  - Partition Key: Identify a field in your JSON for partition optimization
  - Timestamp Policy: Choose between arrival time or event time (application timestamp)
  - Backfill Option: Configure if historical data processing is needed
  - Input Validation: Enable to verify schema compliance and improve resiliency
  2. JSON Schema Definition
  - Schema Inference: Decide between automatic or explicit schema definition
  - CREATE TABLE: Define explicit schema for reliable processing using ASA's CREATE TABLE
  - Data Types: Map JSON types to appropriate SQL types (string → nvarchar, numeric → decimal/int)
  - Complex Types: Handle nested objects and arrays with proper extraction functions
  - Default Values: Set default values for missing fields if needed
  3. Stream Analytics Query Design
  - Query Optimization: Structure query for efficient processing
  - Temporal Windows: Define tumbling/sliding/hopping windows if aggregation is needed
  - Functions: Implement UDFs for complex transformations if required
  - Error Handling: Use TRY_CAST functions to prevent job failures
  - Partition Hints: Leverage PARTITION BY for parallelism
  - Reference Data: Include reference data joins if required for enrichment
  4. SQL Database Output Configuration
  - Table Design:
    - Primary Key constraints
    - Clustered/Non-clustered indexes on frequently queried columns
    - Appropriate column data types matching ASA output
    - Partitioning scheme if high volume
    - Compression settings for large tables
  - Batch Settings:
    - Max batch count (recommended: 10,000 for optimal performance)
    - Batch size (recommended: 1-2 MB)
  - Authentication: Use Managed Identity for secure connection
  - Retry Policy: Configure appropriate retry settings
  - Column Mapping: Define explicit column mapping if field names differ
  5. Performance Optimization
  - Streaming Units (SUs): Allocate appropriate SUs (start with at least 6 SUs for production)
  - Partitioning Strategy:
    - Enable "Inherit Partitioning" option for parallelism
    - Ensure balanced partitioning to avoid hotspots
  - SQL Database Tier: Select appropriate service tier (Premium/Business Critical for high throughput)
  - SQL Indexing Strategy: Implement proper indices on frequently queried columns
  - Compatibility Level: Use latest ASA compatibility level for best performance
  - Watermark Delay: Monitor and optimize to maintain processing speed
  6. Monitoring & Alerting
  - Key Metrics to Monitor:
    - Watermark delay (target <10 seconds for real-time processing)
    - SU utilization (target <80%)
    - Input/Output events rate
    - Runtime errors
    - Failed function calls
    - Resource utilization
  - Alert Thresholds:
    - Watermark delay > 1 minute
    - SU utilization > 80% for 15+ minutes
    - Runtime errors > 0
    - Input events with deserialization errors
  - Logging Configuration:
    - Enable diagnostic logs
    - Set up Log Analytics workspace
    - Configure proper retention period
  7. Error Handling & Data Quality
  - Input Data Validation: Implement schema validation at input
  - Dead-letter Path: Configure for invalid/unprocessable events
  - Error Handling Strategy:
    - DROP errors: Discard invalid records
    - RETRY: For transient failures
    - Exception path for detailed troubleshooting
  - Data Quality Checks:
    - Implement checksum validation if applicable
    - Set up data quality monitoring dashboards
  8. Security & Compliance
  - Data Encryption: Enable encryption at rest and in transit
  - Secure Authentication:
    - Use Azure Active Directory (AAD) and Managed Identity
    - Avoid shared credentials/connection strings
  - Network Security:
    - Implement Private Endpoints or Service Endpoints
    - Configure firewall rules appropriately
  - Auditing: Enable SQL auditing for compliance requirements
  - Access Control: Implement proper RBAC for both ASA and SQL
  9. Disaster Recovery & Business Continuity
  - Geo-replication: Set up SQL geo-replication if needed
  - Backup Strategy: Configure SQL automated backups
  - Job Recovery Plan: Document steps for job recovery
  - Configuration Versioning: Store job definitions in source control
  - Failover Testing: Regularly test failover scenarios
  10. Deployment & DevOps
  - CI/CD Pipeline: Implement automated deployment
  - Environment Promotion: Dev → Test → Prod strategy
  - ARM Templates/Bicep: Infrastructure as code for reproducibility
  - Feature Flags: For controlled rollout of changes
  - Blue-Green Deployment: For zero-downtime updates
  11. Cost Optimization
  - Right-sizing: Adjust SUs based on actual load patterns
  - SQL Resource Optimization: Implement elastic pools if applicable
  - Data Lifecycle Management: Configure data retention/archiving
  - Scheduled Scaling: Implement scheduled scaling for predictable workloads
  - Cost Monitoring: Set up cost alerts and regular reviews
  12. Documentation & Governance
  - Data Dictionary: Document all fields and their mappings
  - SLA Definitions: Define performance and availability SLAs
  - Runbook: Create operational procedures for common issues
  - Change Management: Establish change control processes
  - Knowledge Transfer: Ensure team training on the solution
https://learn.microsoft.com/en-us/azure/stream-analytics/
https://learn.microsoft.com/en-us/stream-analytics-query/stream-analytics-query-language-reference
0 additional answers
