Tables are not showing up in Azure data studio
Luke Manthuruthil 0 Reputation points
2025-04-10T17:45:24.09+00:00
had Power BI connected through an Azure database, and it was working fine previously. However, the refresh recently failed. When I checked the database in Azure Data Studio, the only table I could see was one named "Dropped Ledger." I'm not sure what caused this, and it appears that all other tables are missing or inaccessible.
Azure Data Studio
Azure Data Studio
A cross-platform database tool for data professionals using on-premises and cloud data platforms on Windows, macOS, and Linux.
  1. Sai Raghunadh M 4,575 Reputation points Microsoft External Staff Moderator
    2025-04-10T19:13:12.9566667+00:00
    Hi @ Luke Manthuruthil
    It seems there has been a significant change on the database side. If you only see a single table ("Dropped Ledger") and the other tables are missing in Azure Data Studio,
    Here are a few steps to help troubleshoot and potentially recover access to the missing data:
    Sometimes, metadata tools like the object explorer don’t show everything. Try this:
    SELECT name, type_desc
    FROM sys.objects
    WHERE type_desc = 'USER_TABLE';
    If this returns nothing, then user tables might have been dropped, or you're not seeing them due to schema changes.
    Sometimes tables can be moved under a different schema. Run:
    SELECT TABLE_SCHEMA, TABLE_NAME
    FROM INFORMATION_SCHEMA.TABLES
    WHERE TABLE_TYPE = 'BASE TABLE';
    This will show all user-accessible tables across all schemas.
    If Power BI refresh failed and now you can't see the data, it's possible the data source schema changed.
    Check Power BI error messages — they might give more clues (e.g., "table does not exist", "invalid schema", etc.).
    Hope this helps. Do let us know if you any further queries.
    If this answers your query, do click Accept Answer and Yes for was this answer helpful. And, if you have any further query do let us know.
