Is Shadow Volume drivers compromised?
2024-12-10T15:33:00+00:00
Microsoft Windows [Version 10.0.19045.5198]
(c) Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>dism /online /cleanup-image /restorehealth
Deployment Image Servicing and Management tool
Version: 10.0.19041.3636
Image Version: 10.0.19045.5198
[==========================100.0%==========================] The restore operation completed successfully.
The operation completed successfully.
Running Build version shows Build 19401.vb_release.191206-1406 (paint desktop version)
Version numbers don't seem to match.
Is Shadow Volume driver compromised? Is there someway to download a clean DISM ultility?
***Moved from Windows / Windows 10 / Security and privacy***
Windows for business | Windows Client for IT Pros | Storage high availability | Clustering and high availability
    2024-12-12T07:21:18+00:00
    There is no need to download dism.exe manually. Since it's a system file, you can just run sfc /scannow to repair it if it's corrupted or deleted.
