0x80073701 error while installing IIS features on Windows Server 2019
2022-06-29T10:42:00+00:00
Windows Server 2019 cannot install IIS features on Server Manager - Add Rolls and Features
Error
0x80073701
The Referenced assembly could not be found
Actions attempted but no lucks
  1. "Specify alternate path"
    Tried to install from the DVD install media; E:\sources\sxs
  2. Run from elevated CMD: "DISM /Online /Cleanup-Image /RestoreHealth /Source:E:\sources"
Others
microsoft-windows-netfx3-ondemand-package.cab was in the DVD media
Please kindly advise me if I can try something else other than re-installing the OS from scratch.
Regards,
Windows for business | Windows Server | User experience | Create a workspace
    2022-06-29T11:14:14+00:00
    Hi Alexandria,
    I am Dave, I will help you with this.
    I apologize, Community is just a consumer forum, due to the scope of your question (Server 2019) can you please post this question to our sister forum on Microsoft Q&A in the Server 2019 section (linked below)
    Over there you will have access to a host of Server 2019 experts and will get a knowledgeable and quick answer to this question.
    https://docs.microsoft.com/en-us/answers/topics...
    2022-07-07T11:39:44+00:00
    Hello Alexandria Tilson,
    The above error 0x80073701 can be resolved with the help of the built-in Windows Update Troubleshooter. You must follow the below fixes to resolve the error,
    1. Run System File Checker
    2. Run DISM Tool
    3. Check Logs and Remove Patches
    • Check for the Windows updates.
    • Maybe the error 0x80073701 was triggered by some temporary server issues.
    • Go back to the Settingsoption, select **Update,**and Security, and click on Windows Update.
    • Press the Check for updates button, and try to update your Server again.
    • If the problem still persists, then restartyour Server.
    Run the Update Troubleshooter to encounter the issue:
    • Navigate to Settings, and select the Update and Securityoption.
    • Then on the left-hand panel, click on Troubleshoot option.
    • Click on View additional troubleshooters.
    • Locate and launch the Update troubleshooter.
    Run System File Checker:
    The error 0x80073701 might be caused due to a missing system file. So to resolve the issue, try System File Checker,
    • Open the Command Promptwith Admin rights.
    • Now**, typethe command given below,**
    • Type sfc /scannowand press Enterto proceed further.
    • **Note:**Don't close the command prompt windows until 100% complete message verification is done.
    • Thus, when the process completes, you will be able to install IIS features on Windows Server and check whether the 0x80073701 error is resolved or not.
    Run DISM Tool:
    • Type cmd in the Windows Start Search box.
    • Right-click on the Command Prompt and go with the option Runas administrator.
    • Now, enter the belowcommand,
    • dism /online /cleanup-image /startcomponentcleanup
    • Nextly, restartyour computer to take effect and check if the issue is resolved and whether you can install IIS features on the windows server or not.
    Check Logs and Remove Patches:
    You will have to check the CBS.log and remove the patches in this method to resolve the error 0x80073701.
    TheCBS.logis a file that includes logs about components when they get installed or uninstalled during updates.
    The CBS.log file is located in the %windir%\Logs\CBS folder.
    If you find any error, then re-install a particular file.
    But, If there is no error in the CBS.log, you must execute the below command,
    DISM /Online /Cleanup-Image /ScanHealth
    This command can check for component store corruption. Hence when the command completes successfully, you will be able to install the IIS feature on your Windows Server.
    I hope the above fixes help you resolve the error **0x80073701,**and you can install IIS features to your Server.
    Regards,
    Austin_M.
