Print Server not visible, can't print, can't see printers to add.
2024-09-06T16:05:08+00:00
Windows Server 2016
Up & running fine for 3+ years
Now can't print.
Printers show idle
Try to print test page, get error to restart print spooler or server with print service
Have restarted both print spooler and server hosting print server
printers can be added direct with IP
works fine from the server - fails from workstation, even logged in as Administrator (which worked on server)
Help?
Please and thank you!
K
Windows for business | Windows Server | User experience | Print, fax, and scan
    2024-09-09T03:02:16+00:00
    To troubleshoot this issue, we'll need to gather more information and perform some diagnostic steps.
    1. Have you made any recent configurations changes or installed updates on the server or workstations?
    2. When you print a test page from a workstation, does it provide any specific error code?
    3. Have you checked the event logs on the server and on the workstations for any related errors or warnings?
    How to turn on the Operational log:
    • Open the Event Viewer on the client machine
    • Expand Applications and Services Logs
    • Expand the Microsoft folder
    • Expand the Windows folder.
    • Expand the PrintService folder.
    • Right-click the Operational log, and click Enable Log.
    •Open the Print Operational Event Logs - any errors generated on the print server console?
    Print Job Status https://technet.microsoft.com/en-us/library/cc773899(v=ws.10).aspx
    Print Router Status https://technet.microsoft.com/en-us/library/dd393189(v=ws.10).aspx
    Printer Connections Status https://technet.microsoft.com/en-us/library/dd393232(v=ws.10).aspx
    1. Can you attempt to reinstall the printer driver on one of the workstations to see if that resolves the issue? Sometimes corrupted or outdated drivers can cause printing problems.
    Best regards,
    Karlie
