Azure Key Vault Encrypt with AES returns 413 Request Entity Too Large
Bobby Bridges 0 Reputation points
2025-02-04T18:25:25.89+00:00
I'm using a 256 bit AES key that's stored in Azure Managed HSM and I'm trying to encrypt data using the Azure SDK. When I try to encrypt the data using the AES key, the SDK returns a 413 Request Entity Too Large error. The data is likely in JSON format and I'm using Encoding.UTF8.GetBytes prior to making the Encrypt call with the SDK. Do you have any suggestions to avoid this error?
Azure Key Vault
Azure Key Vault
An Azure service that is used to manage and protect cryptographic keys and other secrets used by cloud apps and services.
Azure Dedicated HSM
Azure Dedicated HSM
An Azure service that provides hardware security module management.
  1. Akhilesh Vallamkonda 15,275 Reputation points Moderator
    2025-02-04T21:17:11.93+00:00
    Hi @Bobby Bridges
    Thank you for posting Microsoft Q&A Forum!
    The 413 Request Entity Too Large error typically occurs when the size of the data being sent exceeds the maximum allowed limit.
    Sign and verify operations algorithms must match the key type, otherwise service will return key size is incorrect error. could you please verify Key types, algorithms, and operations and Azure Key Vault service limits is compatible.
