Azure c SDK reportedproperty Not working
2024-09-26T12:13:53.9066667+00:00
Hello All,
I am working in azure c SDK(lts_03_2024). I working in the device twin implementation. I checked that using API for the reported property I can't update device twin in the IoT Hub in a thread function which is waiting for sensor data.Can you please help me to solve this.NB:I am using High level API
Thank you
Azure IoT Hub
Azure IoT Hub
An Azure service that enables bidirectional communication between internet of things (IoT) devices and applications.
  1. Deleted
  2. Deleted
