Help with sign-in problem
Elda 0 Reputation points
2024-09-20T15:56:47.04+00:00
When I try to connect to e specific network it says "Can't connect because sign-in requirements for your device and the network aren't compatible, please contact your IT support" . Can you please help me with that?
Windows for business | Windows Client for IT Pros | Networking | Network connectivity and file sharing
Windows for business | Windows Client for IT Pros | User experience | Other
  1. Bruce (SqlWork.com) 85,201 Reputation points
    2024-09-20T16:24:33.5133333+00:00
    this generally means the network you are trying to connect with requires security software be installed on your device. if the security software is installed, then your device is not in compliance with the security requirements.
    as suggested, contact the admin of the network you are trying to connect with and get their requirements.
