Vision Studio wont find nor create a resource due to 'missing' resource group.
Vincent Lenngren 0 Reputation points
2024-09-11T06:28:38.0833333+00:00
When I try to do a new test with OCR of a PDF I want to drag and drop it and need to select or create a resource first. OK no problems I think, since I did another test before where I labeled and analyzed pictures in Vision Studio before. Big problem... I have cleaned up old stuff and think I'll create a new resource. But it wont find my Resource Group! I even tried to create new ones, but no luck.Capture2
Azure AI Custom Vision
An Azure artificial intelligence service and end-to-end platform for applying computer vision to specific domains.
Azure Vision in Foundry Tools
  1. navba-MSFT 27,625 Reputation points Microsoft Employee Moderator
    2024-09-11T07:17:14.08+00:00
    @Vincent Lenngren I'm glad to hear that the issue is resolved. Thanks for posting your solution so that others experiencing the same thing can easily reference this. Since the Microsoft Q&A community has a policy that the question author cannot accept their own answer, they can only accept answers by others, I'll repost your solution in case you'd like to Accept the answer.
    Issue:
    In the Vision Studio, under the create a new resource your vision resources are not loading.
    Resolution:
    This seemed like a transient issue and now the resources are loading just fine in the Vision Studio.
