A Microsoft communications service that provides communications capabilities across presence, instant messaging, audio/video calling, and an online meeting experience that includes audio, video, and web conferencing.
Same problem here -- fedora 34 - all updates applied, X11, KDE..
It hangs for a minute or so, then resumes as if nothing had happened..
Disabling hardware acceleration does not help.
Interestingly sometimes it survives for 2 hours of video group chats, then dies after it finishes.
I edited its /usr/bin/teams so it shows the errors etc on the console, and here is what it wrote:
[turgut@tk-minilaptop bin]$ teams
Error while parsing hooks JSON. Error: "ENOENT: no such file or directory, open '/home/turgut/.config/Microsoft/Microsoft Teams/hooks.json'"
(node:137752) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
(node:137752) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 ecsSettingsUpdated listeners added to [EventEmitter]. Use emitter.setMaxListeners() to increase limit
(node:137752) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 appInitialized listeners added to [EventEmitter]. Use emitter.setMaxListeners() to increase limit
(node:137752) UnhandledPromiseRejectionWarning: Error: LocalStorageService: key or value not defined
at m.<anonymous> (/usr/share/teams/resources/app.asar/main.bundle.js:1:401202)
at Generator.next (<anonymous>)
at /usr/share/teams/resources/app.asar/main.bundle.js:1:399460
at new Promise (<anonymous>)
at i (/usr/share/teams/resources/app.asar/main.bundle.js:1:399205)
at m.setValue (/usr/share/teams/resources/app.asar/main.bundle.js:1:401144)
at t.AppLevel.set (/usr/share/teams/resources/app.asar/main.bundle.js:16:681777)
at /usr/share/teams/resources/app.asar/main.bundle.js:16:689507
at Array.forEach (<anonymous>)
at t.appPreferenceKeys.reduce.n (/usr/share/teams/resources/app.asar/main.bundle.js:16:689454)
(node:137752) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
(node:137752) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
(node:137752) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
