An Azure service that automates the access and use of data across clouds without writing code.
Problem connecting logic apps to container with managed identity
Hi Team,
I recently transitioned my Logic App workflow from using an access key to a managed identity for my storage account connection. However, after disabling the access key, all my workflows disappeared, and the Logic App started encountering errors.
Here's a summary of my setup:
- Logic App: Used to automate processes involving data in a storage account.
- Storage Account: Initially connected using an access key, now using a managed identity.
Steps I took:
- Enabled managed identity for the Logic App.
- Granted the managed identity appropriate permissions on the storage account.
- Updated the Logic App connection to use the managed identity.
- Disabled the access key for the storage account.
Expected Outcome:
- Workflows should continue functioning seamlessly after switching to the managed identity.
Actual Outcome:
- Workflows disappeared from the Logic App designer.
- Logic App throws errors related to missing workflows.
Has anyone else encountered this issue? Any insights or suggestions on how to troubleshoot and restore my workflows would be greatly appreciated.
Thanks in advance for your help!
Azure Logic Apps
