I have multiple users whose default printer keeps changing to a "virtual" printer such as the Adobe PDF printer
Gonzales, Caryl 5 Reputation points
2024-05-23T15:14:38.5733333+00:00
Azure Virtual Desktop
A Microsoft desktop and app virtualization service that runs on Azure. Previously known as Windows Virtual Desktop.
Windows for business | Windows Client for IT Pros | User experience | FSLogix
  1. Sina Salam 31,456 Reputation points Volunteer Moderator
    2024-05-23T22:21:17.31+00:00
    Hello Gonzales, Caryl,
    Welcome to the Microsoft Q&A and thank you for reaching out.
    I understand that you are having issues with multiple users whose default printer keeps changing to a "virtual" printer such as the Adobe PDF printer
    When multiple users experience their default printer changing to a "virtual" printer such as the Adobe PDF printer, it can be highly frustrating and disruptive. Try as much as possible to do the followings:
    • Adobe Acrobat and Reader can sometimes change the default printer, you will have to prevent this by adjusting Adobe settings.
    • Ensure that your Group Policy settings are not inadvertently setting the default printer to a virtual printer.
    • Ensure the default printer is set correctly at the user level from Device and printer.
    • Ensure all printer drivers are up-to-date and correctly installed.
    • If users have roaming profiles, ensure that their printer settings are properly saved and loaded.
    I hope this is helpful! Do not hesitate to let me know if you have any other questions.
    ** Please don't forget to close up the thread here by upvoting and accept it as an answer if it is helpful ** so that others in the community facing similar issues can easily find the solution.
    Best Regards,
    Sina Salam
