How to fix error code 0x80070057
w raspe 341 Reputation points
2024-04-12T07:11:01.3666667+00:00
Hi all,
I have installed an clean Windows 11 version 23H2.
I configured a provisioning package with Windows configuration designer (ICD)
Configured the package as follow:
icd1
When I want to apply this provisioning package I get the following error message:
error icd
To fix this I have tried the following, but with no results:
  • windows update
  • making sure to use the latest version of Microsoft Edge
  • tried different versions of ADK
  • sfc /scannow
  • Changing app type from universal windows app to classic, with following command "C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe"
Windows for business | Windows Client for IT Pros | Devices and deployment | Set up, install, or upgrade
Microsoft Security | Intune | Configuration Manager | Deployment
Windows for business | Windows Client for IT Pros | User experience | Other
  1. Wesley Li 11,860 Reputation points
    2024-04-12T09:57:50.92+00:00
    Hello
    It seems like you're encountering an error when applying a provisioning package on Windows 11, and you've already tried several troubleshooting steps.
    Error Code 0x80070057: This error usually indicates an invalid parameter or an incorrect value specified in a command or operation. It might be worth double-checking the settings within your provisioning package to ensure all parameters are correctly configured.
    Provisioning Package Compatibility: Verify that the provisioning package you've created is compatible with Windows 11 version 23H2. Sometimes, certain settings or configurations might not be supported in specific Windows versions.
    Event Viewer Logs: Check the Event Viewer for any related error messages or warnings that might provide more details about why the provisioning package failed to apply. Look for entries around the time of the error occurrence in both the Application and System logs.
    Group Policy and Registry Settings: If your provisioning package includes any Group Policy or registry settings, ensure they are correctly configured and not conflicting with existing settings on the system.
    Permissions and User Account Control (UAC): Ensure that you're applying the provisioning package with administrative privileges and that UAC settings are not blocking the installation process.
    Test on Another System: Try applying the provisioning package on a different Windows 11 system to see if the issue is specific to the target system or if it's a broader compatibility issue.
  2. w raspe 341 Reputation points
    2024-04-12T13:11:05.93+00:00
    Problem is Edge itself. parameters are fine.
    https://learn.microsoft.com/en-us/answers/questions/204877/assigned-access-will-not-start
    The AppID of Microsoft Edge is not able to start in kiosk mode.
    error1
    When I try below app as kiosk it works perfect
    error2
    few years ago it would work with Microsoft.MicrosoftEdge_8wekyb3d8bbwe!MicrosoftEdge
  3. Maxym Zayarnyuk 1 Reputation point
    2026-06-24T05:15:07.7066667+00:00
    had same on old version of x64; and only with one user;
    think can be - is corrupted access rights to some path or reg keys for metro/uwp app;
    or run or reg of dcom process that needed for that app;
    gppolice edits can be issue too (if you prevent system from access some data etc);
    on my case similar error because I blocked it in some way for better security; and now forgot what I changed;
    0x80070057: Cannot create the Desktop AppX container for package 52601TheDesktopBridge.2261331D290CD_1.1.0.0_x86__qfm5jy7hkm90p because an error was encountered configuring the runtime.
    0x80070057: Cannot create the process for package 52601TheDesktopBridge.2261331D290CD_1.1.0.0_x86__qfm5jy7hkm90p because an error was encountered while configuring runtime. [LaunchProcess]
    is sample of ms app to start com application via desktop bridge (com interop from UWP);
    on other pc users that app work;
