How to debug Azure IoT Operation Data pipeline failure
Hennessy, Tim 25 Reputation points
2024-03-26T20:00:11.1166667+00:00
I am working through an Azure IoT Operations QuickStart article regarding the Data processor. After setting up the passthrough pipeline and saving it, it never syncs correctly.
I dumped the pipeline information and get this error information
Provisioning Status: Error: Code: RunnerGRPC Message: The operator failed to establish a connection with the Runner-worker. Failure Cause: Unknown Operation Id: c2048032-b4d2-4313-98b0-3a0601313f74*6DD9C1D5D399783A83E02115E1656360F5FC51CBFD7B58D5966752849536D803 Status: Provisioning
So, I decided to delete the pipeline and start over. But I'm unable to delete the pipeline, the pipeline shows this status
Provisioning Status: Error: Operation Id: 9350cec9-f52b-44a3-8576-6ca33f827db7*EFE21F6EAB7808A422435DFB431ECCD15EBA994358893FA59145E702BAD8DAFA Status: Deleting
Is this a known issue with the QuickStart? What steps can I take to get the pipeline sync to succeed?
Azure IoT Operations is a set of modular services enabled by Azure Arc.
  1. LeelaRajeshSayana-MSFT 17,871 Reputation points Moderator
    2024-03-27T22:44:58.9266667+00:00
    Hi @Hennessy, Tim The product team's initial analysis on this issue, based on the logging message, seems to be a deployment issue. The team has requested for additional logs which can be collected using the CLI command az iot ops support create-bundle. The command creates a standard support bundle zip which you can share with us offline to further investigate this issue.
    Update
    Root cause is still being analyzed for the behavior. Thread will be updating with further findings. As a work around, create a new set of resources to overcome the issue.
    If the response helped, please do click Accept Answer and Yes for the answer provided. Doing so would help other community members with similar issue identify the solution. I highly appreciate your contribution to the community.
