Use PIN as the default login method
Mountain Pond 1,716 Reputation points
2023-06-16T10:19:17.1433333+00:00
Hello, after WIndows Hello has been set up, the device is still asking for a password and the user needs to manually select a PIN to log in using the PIN.
vmconnect_QkQsUYbZTy
Can I force and prioritize a PIN using Intune?
msedge_bRiG0hE1ZE
The network has instructions on how to do it for a specific user. By setting a per-user value in the registry, but I can't do it per device. Of course, you can write a script that will determine the SID of the current user, make sure that Windows Hello is configured and change its value. But all this will be performed from the system and this is not a good solution at all.
Thank you.
Microsoft Security | Intune | Other
Crystal-MSFT 54,326 Reputation points Microsoft External Staff
2023-06-19T05:07:42.3733333+00:00
@Mountain Pond, Thanks for posting in Q&A. Based on my researching, when you sign-in to your user account or unlock the workstation, the last used sign-in method (PIN, Password or Windows Hello) is saved to the registry, and the same will be used the next time. The last sign-in mechanism is stored in the following key, in the value name that matches your user account SID:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Authentication\LogonUI\UserTile
You can let users to sign in with PIN and then see if the PIN will be the default sign in option next time.
If not, you can check if auto login is set, If yes, disable automatic login to see if it works.
Hope it can help.
0 additional answers
