High CPU usage for vmmem
Steve Lo 135 Reputation points
2023-03-21T19:12:59.2566667+00:00
I have experienced high CPU usage for Vmmem frequently (~every 2days) and the only solution at the moment is simply restart my machine.
It is understood that is related to WSL and I do have a Docker image running on Ubuntu on Windows. However it is not really responding for Ubuntu and Docker (see below) and CPU usage is still that high even I manually close Docker Desktop and run cmd wsl --shutdown.
It's really disruptive for me and any opinion would be appreciated.
Cheers
Steve
Windows for business | Windows Server | User experience | PowerShell
Windows for business | Windows Client for IT Pros | User experience | Other
  1. Limitless Technology 45,246 Reputation points
    2023-03-22T14:19:50.54+00:00
    Hello
    Thank you for your question and reaching out. I can understand you are having query\issues related to vmmem high CPU usage.
    When Docker is running, it uses memory just like any other virtual machine in any virtualizer. Docker is a sort of virtual machine.
    It suggests that you create the following text file at:
    C:\Users<your-username>.wslconfig
    [wsl2]
    memory=2GB # Limits VM memory in WSL 2
    processors=1 # Makes the WSL 1 VM use two virtual processors
    Reference :
    https://devblogs.microsoft.com/oldnewthing/20180717-00/?p=99265
    --If the reply is helpful, please Upvote and Accept as answer--
    2023-06-07T15:54:52.5933333+00:00
    Hi All,
    I use Docker and WSL2 frequently and have run into this problem many times. It seems to happen semi-randomly after some period of time, ~1-2 days.
    I don't have a solution that addresses the core issue with Vmmem but I do have a workaround that doesn't require rebooting my whole machine. For me, going into Task Manager and ending the "Windows Subsystem for Linux" task is sufficient and Vmmem goes back to normal.
    Hope this works and saves people from having to restart every time.
  3. Walker, James (SI BP AM R&D SYS) 85 Reputation points
    2023-07-17T13:47:30.0733333+00:00
    Open cmd prompt, run as admin,
    wsl --shutdown
  4. Petr Bodnár 40 Reputation points
    2023-07-23T10:22:01.23+00:00
    Note that this bug seems to have been discussed at https://github.com/microsoft/WSL/issues/6982 for over 2 years already. From there, it looks like pressing Win+Ctrl+Shift+B could also help, as it resets the graphic (video) driver which apparently causes the issue.
    As stated by WFarmer, stopping the Window Subsystem for Linux (wslhost.exe) should work as well. In the linked thread, restarting the Windows service called WslService could help as well.
    Of course, none of this helps with avoiding the issue altogether, unfortunately.
  5. Antonio Torres Vargas 0 Reputation points
    2023-09-13T14:57:56.0433333+00:00
    This worked for me.
    Create the following text file at:
    [wsl2]
    guiApplications=false
    then restart the PC
