Delete StorSimple Device - After EoL
2023-03-14T19:06:39.89+00:00
I am tidying up our Azure account and have deleted the associated Storage account we had for our StorSimple.
However, how do we delete the StorSimple device as the StorSimple Device Manager has no options and just says it's end of life.
I have tried running some powershell commands to get the name of device and deleting via CLI but will not work.
StorSimple
StorSimple
A Microsoft hybrid cloud storage solution that combines on premise hardware storage and cloud storage.
  1. SaiKishor-MSFT 17,341 Reputation points Moderator
    2023-03-16T17:12:46.2166667+00:00
    @Samuel Tamkin | Workplace Connect I apologize for the delay in responding to your question.
    I checked with our internal team regarding this and itseems like the best way to resolve this issue would be to reach out to Azure Support directly as they will have a process to navigate this issue.
    If you do not have a Support Plan, please send mail to AzCommunity [at] microsoft dot com with subject: "ATTN: Sai Kishor" include your Azure subscription ID and a link to this forum thread (for context). We would like to enable one time free technical support on your subscription to put you through Azure backup technical support team to get quick resolution to your issue.
    Thank you!
